Hey guys,
I bought a Beogram 3000 (1986 version) yesterday, it works but has some issues with the tonearm and i was hoping you guys knew what the problem is and how it can be fixed..
-When i press play the tonearm goes down a little too much to the right and "falls" of the record, it does this both with full size LP's and singles.
-It also won't stop automatically when it reaches the end.
-I'm able to slide it's position to the left manually (with the arrow-button) but not to the right. :s
-When i lift (press stop) in the middle of a record it goes up, but it drags a little to the left first :s
I bought it as working and hope it's an easy fix because i'm not that mechanically knowledgeable.
Friendly greetings,
Milo
