I bought this cheap from a local guy and other than it having a missing stylus (although with a MMC4 cartridge) the only other problem was that it wouldn't power up, I've had a multimeter on it and cannot detect any kind of electrical life whatsoever.I have re-soldered all the connections have drawn the conclusion that the transformer is indeed faulty.
As I mentioned elsewhere I bought some cheap parts from a US seller but of course the transformer is not UK voltage. The transformer itself is part # 8013329 (the identical number to that on the cheap local purchase) it's just that the mains connections and tapping bridges are different. Does anyone know if it's just a simple matter of changing the wiring on the US version to mirror that of the UK transformer? All the other components and connections seem to be identical so I'm hopeful that the solution is a simple one!
Any ideas anyone?
Thanks for any help in advance¬
