Has someone a schema of the motorcontrol unit on the PCB of the motor? I have taken the motor apart and it's running, but the controller PCB has a problem. On the PCB IC808 (hall ic or PWM?), a thyristor, some capacitors and resistors.
I just want to see how this functions and if their are parts availbale. The IC808 search didn't show something on google.
Thank you for help.
Kind regards, Erik
