I then went to work on getting the cueing mechanism etc lubed and functioning as well. That is where I got myself into trouble. I must have installed the white plastic Cam Lifting Wheel incorrectly because it is no longer functioning as it should.
If I turn it manually it will catch the small white gear, but then it goes back to the flat spot of the wheel and does not catch. Does anyone have a picture of how it should be installed at rest?
As it may be obvious from my post, I am not a skilled technician.
In it's current state, it just spins and no switch has any effect on it. It will spin until unplugged. No arm movement, no lift, etc.
