Hello
i totally cleaned my old Beogram : was turning reaaalllllyyyy slow...
worked good and then after a while I had to re open the motor to add some oil (Vaseline oil)... and worked good again ... and then same problem, I had to clean and put a gain oil... etc...
i always have to re open and check ... what shall I do to have it spinning good for the next 10 years ? Is there a good tutorial ? Explaining which kind of oil and what to take care about or what to control ?
should be same as 1200 1201 1202 1203 and 3000....
thank you ;)
