Beogram 1202 Pickup gap
Hi! I am restoring a Beogram 1202. One question; Is it normal that the gap between pickup and record are so small? If not, how do I adjust the gap? //Lars
While it is not the best angle to examine, it does look like the tracking force is too heavy or the stylus's suspension is shot and needs replacement. If it's an SP-10 or 12 it should be 1.2 grams.
Hi, Despite the fact that these are different turntables, the photos on this page should help give you an idea of how things should look
PLEASE READ before sending me a Personal Message. If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department. I cannot be a "short circuit", bypassing these communication channels. Thanks -geoff
a little more information: I just had a look at the service manual for the Beogram 1202 and 3000. The recommended tracking force stated there is:
  • Beogram 1202 with an SP 14 A pickup: 2.0 g equivalent
  • Beogram 3000 with an SP 10 A pickup: 1.2 g equivalent
What Geoff said. - And some aftermarket stylii are better than others... Martin
Thanks Geoff! I will take a look at the pickup. I did set it to 2g, but I am not sure if it is SP10 or SP14. I tried to adjust the three screws for the platter-hight, but if I lower the platter, the pickup-arm stand also lowers. So the gap are constant. //Lars
