B&o 4002
Good afternoon my father has a turntable 4002 with a problem with the position sensor, is there someone not so far from italy that can fix the problem?
Thanks in advance for your help
Veronica
Hi Veronica,
Distance is relative...
I can provide complete restorations to a considerable serious level whereby components and adjustments are made to achieve a really smooth working Beogram 4002 again.
Just troubleshooting isn't always the best option especially when you want to avoid unnecessary transport for that "distance".
BR, Beobuddy.
