Are Bang & Olufsen Beogram RX2 and TX2 platters interchangeable?
The radial surface design seems the same. Are they exactly the same? Moreover, is it easy to exchange them?
Yes, I have both. One was in better condition than the other and I swapped them.
How easy is it to swap them? Do the platters simply lift off?
