- Beolink Passive 1657
- Beolink Active 1636
- Beolink Converter 1611
- Beolink Converter 1614
- MCL2A
- MCL2AV (the one with TV rather than Aux)
- Beolink PC2
My MCL2AV is the version with the TV socket, not the Aux socket, but maybe it would still work?That works the same yes
I had never considered using a Beomaster though, so am interested in that suggestion. How would that work? Would Beomaster 5000 be suitable? Beomaster 5000 seems a good option as I believe that one has a built-in phono stage? Beomaster 5000 will often come up for under £100 on eBay too.Beomaster 5000 wil not work as it is not datalink86 compatible for connection to the 1611 converter. Beomaster 5500 should work, but I remember reading that some of the early versions did not have a software to be compatible.
Beogram 3000 connects to phono input of a Beomaster (5000, ideally) Beocenter 5000 set up as a link room Beocenter 5000 connects to 1611 via Aux Link (would the 1614 not work instead, since the BS4 can work as the audio master?) 1611 connected to BS4 via Masterlink Would that allow me to operate the Beogram via Link>Phono (or Link>N.Radio)?It has to be the Beomaster that is set up as a Master as a link room can not serve its sources to other rooms. Also the older Beomasters/Beocenters can not be setup as link rooms.
My best suggestion would therefore be to connect the Beogram to the CD socket of the MCL2AV, connect a datalink cable from the Aux socket of the MCL2AV to the 1611 converter and let that work as a main room. Then set the BS4 up as a link room (option 5 or 6) and control the Beogram with Link + CD commands.I am joining the discussion because I too think that the MCL2AV may be the best solution. But rather than use a 1611 converter, couldn't you just use the MCL2AV Aux socket to provide a Line-out (DIN pins 1 ad 4) and connect this straight to the BS4 aux inputs? I am not sure if you can then get the BS4 to open the aux input with a phono command, but any subsequent double phono commands (to MCL2AV and BS4) may not be a problem - does that make sense? Maybe this could avoid having to use LINK commands. EDIT: I forgot that N.RADIO = PHONO, so 'double' IR commands may be a problem! Might need to use LINK commands after all! EDIT2: I suggested something similar back here, but then suggested taking output from the (volume controlled) MCL2AV Powerlink sockets. My older post does however remind me that it's only the datalink signal that is required from MCL2AV to Beogram. The Beogram's audio output (pins 3 and 5) could be connected direct to the BS4, via a phono stage. A suitably wired adaptor should work.
I had not thought about using the MCL2AV as only a control device and rerouting the sound directly to the BS4. This would of course require a IR eye connected to the MCL2AV. However the PHONO command can not be used as the MCL2AV will send that to the MCL screw terminal connection. But CD could be used. I do not remember if the MCL2AV can be set in option 4 so it only responds to Link + commands. I can try to make a test of this scenario with my BC2My best suggestion would therefore be to connect the Beogram to the CD socket of the MCL2AV, connect a datalink cable from the Aux socket of the MCL2AV to the 1611 converter and let that work as a main room. Then set the BS4 up as a link room (option 5 or 6) and control the Beogram with Link + CD commands.I am joining the discussion because I too think that the MCL2AV may be the best solution. But rather than use a 1611 converter, couldn’t you just use the MCL2AV Aux socket to provide a Line-out (DIN pins 1 ad 4) and connect this straight to the BS4 aux inputs? I am not sure if you can then get the BS4 to open the aux input with a phono command, but any subsequent double phono commands (to MCL2AV and BS4) may not be a problem – does that make sense? Maybe this could avoid having to use LINK commands. EDIT: I forgot that N.RADIO = PHONO, so ‘double’ IR commands may be a problem! Might need to use LINK commands after all! EDIT2: I suggested something similar back here, but then suggested taking output from the (volume controlled) MCL2AV Powerlink sockets. My older post does however remind me that it’s only the datalink signal that is required from MCL2AV to Beogram. The Beogram’s audio output (pins 3 and 5) could be connected direct to the BS4, via a phono stage. A suitably wired adaptor should work.
Madskp wrote: I do not remember if the MCL2AV can be set in option 4 so it only responds to Link + commands. I don’t believe it can use option 4 – I tried to set it to option 4 but it made no difference – it does not respond to Link commands. I found an old MCL manual online and it seems to only have 1, 2, or 0 available.Actually that makes sense since in the intended use of the MCL2AV where it is connected to a Beomaster/Beocenter with MCL cable a Link + CD command will be sent to the Beomaster down the MCL chain if a local CD player is connected to the MCL2AV. However the MCL handbook has this example where option 4 can be used with for example X-tra active speaker, which is a kit that contains the MCL2AV and an IR eye, but probably the newer version of the MCL2AV with a newer software version. Login to view image If I have time for it I can try to make a test with both the older and the newer MCL2AV in the weekend to see if option 4 works on any of them.
