Like to know how to adjust the droppoint. Noticed this is rather to the edge of the record rim on records. And sometimes it is falling from the record.
nobody here????
Hi there.
I will try to help you. On this model - take off the platter, then take off the Black plastic disc - and then you will see this:
You can then adjust on the two screws A and B.
A for 17cm records (singles) -and B for 30 cm's (Lp's).
Hope this helps you.
Steffen
thanks for sorting this out will try this.
