4002 speed lights
Hi! Anyone know what and or where I can get a speed indicator light? There is only a part number in the manual.
Hi Jim,
It will be interesting to know which kind of 4002 type you own, underneath of the turntable you will find something like "Type 55xx" or on service position, after removing the aluminium cover you will find near the transformer the information required.
That said, 5511,13 up to 5523 the bulb should be Sub Miniature Wire Ended Bulbs 24V 40mA, hope this will help you.
Alternatively you could convert the bulb by LED and I strongly advice to reach "Beolover" who does a special item which has the right coloured illumination.
By the way, do you own one or two stylus guard for a MMC4000 or MMC6000 you will not need ?
If so Email me, thanks.
Steveric, Thanks for the info. My deck is a type 5503 from early 1974. I have ordered new led lights from Beolover. Sorry no extra guards.
Jim.
