4002 5511 Type Inside plastic bearing shaft
Hi Folks,
Look for advise right now about what the suppose looking at the inside of the ended bearing shaft, I noticed the axis of the sub platter as a strange shape and the inside ended bearing has a plastic that looks the same shape of the sub platter, the tiny hole on the plastic parts suppose to be there or suppose to be flat ?
Stay tune for your comments...😮
Can you post some pictures to show what your are looking at?
Thanks,
sonavor
Thanks sonavor for your attention,
It will be a bit tricky, because I don't have the turntable behind me...🙁
Sorry for this second post, I click twice instead of one...👍
What I would like to know is, is that common that the end of the inside bearing has a plastic with a tiny hole in the middle ? and if not do we have a replacement plastic parts like the BG8000 ?
I will try to take a picture of one of mine tonight. I have a Beogram 4002 type 5523 that I can get to and check.
-sonavor
Steveric wrote:
Hi Folks,
Look for advise right now about what the suppose looking at the inside of the ended bearing shaft, I noticed the axis of the sub platter as a strange shape and the inside ended bearing has a plastic that looks the same shape of the sub platter, the tiny hole on the plastic parts suppose to be there or suppose to be flat ? Stay tune for your comments...😮
This is absolutely normal. There is only one sintered bushing at the top and the bottom is self-centered with what you describe.
I found a Beogram 4002 Type 5503 that was easier to get to. Here are a couple of pictures of center hub.
#1
Here is another one.
#2
Thanks a lot sonar and charts, in my recollection it looks more or less the same, so now I'm more confident.😕
I will shoot some pictures, when I will be behind the turntable, that's for sure could help some folks who have in mind the same question.🙂
