Beocord v8000 schermo nero e senza audio
Hello everyone, I'm repairing a v8000 beocord that suddenly the video and audio disappeared, you can only see the writing at the bottom of the command menu.
When I turn it on I hear the hiss of the tuner then when I insert the cassette only the black screen appears.
I've changed all the capacitors except on the power supply board which seems to work fine, cleaned the heads with a cassette cleaner but nothing has changed.
Has anyone had the same problem? how did you solve it?.
Thanks friends
Update, I also changed the capacitors of the power supply card, now the audio can be heard and cannot be seen (black screen).
Advice?
Can anyone help me?
The screen is black, only audio is heard
