Beocord 9000 - keypad not responding
I bought a Beocord 9000 and did various repair - but it is not responding at all activating buttons on the keypad panel. I powers up and I and there is light in the dispay + cassette drawer. All belts are changed and capstan is running. All leafspring concats looks good. I can meassure the -24, 24, 32, 13 volts on the board 6. I can also meassure 6.2 and 5 volts on the board 1 - didnt check all testpoints here. But looking at P21 wire 3 in the servicemanual it says 5.5 Vp and shows some kind of pulse or AC curve. The P21 wire 3 only feed the IC1 (input/output expander) pin 38 texted 50/60hz. Meassuring P21 wire 3 I have: 1,6v DC and 0,7v AC connected to the board 1 2,7 DC and 1,7v AC no load My very bad usb oscilloscope shows nothing.... Could this be my problem? Best regards baek47
I also recapped all brown/orange ROE capacitors. I replace the 4.7v zener before the P21 wire 3.
I also recapped all brown/orange ROE capacitors. I replaced the 4.7v zener before the P21 wire 3.
Some versions have a fuse on the display board. Have you checked? Martin
Hi Martin Yes, it is good and the IC1-3 are getting 4,8 v. I also checked that I have continuity on the display board when activating buttons on the keypad. Since my my last post I changed all transistors (and caps) on the "display board 1" and the "digital/analog converter board 11" - no change except that the "rec.cal." on the display board isnt lit anymore. And resoldered almost all joints as well.... By the way, my model is the first, below 2831001. Next I will go through the Osc. board 13 and Rec/ampl. board 3....but advices are welcome Regards Torben
