Just working on my BC7000 which has some voltage issues:
I can not find the 22VAC, which serves two connection ? All I am getting is 28VAC.
That brings me to the question if it is actually a transformer problem ?
Would like to know its typical VAC output voltages.
I am also missing the 12VdC supply for the drive which I should be see at
Plug16- pin4 ??
I have gone over the power supply board without finding any suspects.
Would really appreciate some help - thanks
ALF
