I am working on a beocord 6500 (type 4938) that is having issues performing any mechanical functions.
The capstan belt has been replaced, the pinch roller has been cleaned and functions fine.
What I am observing is that when pressing play, the tape head/pinch roller will raise but there is no motion from the reels. At the same time, I can hear the mechanism motor still trying to move. After a few seconds, the reel motor will very briefly spin and the unit will go into standby (I'm guessing due to excess current from the struggling mechanism motor).
It seems that mechanical failure as the cause is unlikely because if you attempt these functions when the unit has been off for a few minutes, it will go into play, turn the head, etc. However, after a few commands are entered, it will fail in the same way (reel motor doesnt turn, mechanism motor struggles, unit shuts off). I can turn the unit off for 5 minutes, come back to it and get another 10-30 seconds of functionality from it before it fails again.
On the control board, all caps tested good. There was a resistor that appeared to have gotten hot attached to IC1, an LM324N. I replaced both the resistor and the IC, no change in behavior. I also read an old beoworld post where a user described adding a 220nf cap and 1ohm resistor in series to ground from the outputs of the L272M's on the board (per the recommendation of the L272M datasheet), this had no effect for me.
Has anyone encountered anything like this with these units?
Any help is greatly appreciated. Please let me know if I can provide any additional detail or clarify anything.
