Beocord 5500 will not stop
I have just replaced the two belts within my Beocord 5500 and powered it up. Both belts seem to be doing their job. When I press Play, FF, RWD & Turn on the main keypad the cassette transport mechanism does what one would expect, and the tape goes in both directions. If I press the Play button on the fascia it starts and stops. (The drive pins continue to rotate for ~4 seconds). But ... if I press Stop on the main keypad, whilst the tape mechanism stops & the pinch rollers retract, the drive "pins" do _not_ stop rotating, unless I press Play on the fascia twice, and/or turn off the power. So it looks like the Stop button on the control panel is only activating the head & pinch roller retraction, and not stopping the drive motor. I have undone & re-seated the ribbon cables, & I am 99.9% sure they are good. I never needed to remove the ribbon cable that goes to the main control panel, so I can't see how I could have mucked that up. Any ideas? Whilst I have downloaded the Service Manual, interpreting the electrical diagrams is beyond my pay grade. Many thanks!
Not sure what you mean by "drive pins" ... a picture?
I assume that you are asking about the capstans? I'm not familiar with the BC5500, but on other Beocords the capstan turns whenever the deck is not in standby. Glitch
Sorry for not being clearer. By "drive pins" I mean did mean the capstans, yes - I had thought that the capstans were the plastic "gears" that go through the centre of the cassette. My bad.
  • When I turn the deck on the capstans (and flywheels below etc) are stationery
  • When I press PLAY (on the slide out control panel or front panel or Master Control Panel) the capstans rotate & the tape plays
  • When I press STOP on the fascia the tape & the capstans stop. (The capstans actually continue to rotate for ~4 seconds, then stop).
  • When I press STOP on the slide out control panel OR the Master Control Panel the tape mechanism stops & the pinch rollers retract, BUT the capstans do _not_ stop rotating, unless I press Play on the fascia twice, and/or turn off the power.
It wears out the motor brushes instead. Anyway - your deck acts normally. Martin
