Beocord 3500 odd behaviour
Hello all,
I'm looking for help in getting my Beocord back to full health so I can enjoy my tapes to the full.
I have some video of my problem and some still photos too.
The issue concerns the wind mechanism - sometimes the tape will auto-reverse randomly. Sometimes it just stops. Rewind and fast forward sometimes work, sometimes don't. In each instance the tape is not tight.
I have the single belt version with the slower, smoother action. I fitted a new belt recently. Both large metal wheels are clean as are the two smaller plastic wheels.
Can anyone tell me what might be causing the issues in the attached video?
Kind regards, Julian.
Beofan for many years with a penchant for 1990s audio systems.
In order to check:
Bad tape.
Seized reel table. Take apart, clean and relubricate.
Problem with reel table brake.
Good job!
The reel tables carry the spindles with tridents that grips into the spools with the tape.
The reel tables carry the spindles with tridents that grips into the spools with the tape. Martin
Hi again. Cool thank you for that - I feel certain you're correct. I just checked both sides: the take-up reel is stiff and the reel table appears to be dragging on the mounting plate. The supply reel moves a lot more freely and is looks to be sitting almost 1mm away from the mounting plate. Photos below. So how can I release the position of the take-up reel table so it isn't in contact with the mounting plate? This is a mega challenge :)
Here is a photo of the rear of the mechanism. It shows a very small almost cross-headed screw (v small) which appears to be the spindle on which the take-up reel table is set into the mounting plate with. I feel quite sure I should not be attempting to adjust that!
Actually on even closer inspection the reel table, as I understand it, appears to have become seperated from the plastic gear wheel just beneath the spring and the trident. Perhaps I can gently prize the reel table off the mounting plate and squeeze it and the plastic gear wheel together? Julian
Yes, the magnet has come lose.
You must take off the the reel table and glue the magnet back onto it.
