The recording tape head seems to be aligned correctly, as are the tape guiding pins connected to it. I've checked the connections inside (there are two cable connectors connecting the tape mechanism to the main board), and they are fine. I cleaned it up inside, and cleaned the recording tape head, but it remains the same - it is only recording the right channel.
The two datalink pins had been removed from the DIN plug by the previous owner, but the 5 remaining pins are there. I guess it could be a loose connection in the cable, but I'm reluctant to try and take that apart unless I know that the problem lies there.
Any advice would (as always) be appreciated.
