Beocom 2 joystick broken
Is it possible to remove (a few) of the buttons on the keypad, in order to glue back the joystick that has broken?
Hi Hiort, yes it is possible to remove buttons. you need to put something flat(corner of credit card for example) below the button and just push it upwards - from the bottom of the phone in to the direction of the screen. And it will click off. The same other way round to put it back.   Hope, I explained it understandable way =)
Thanks, I skipped the phone in the end. Its lying dead in a drawer....
What version do you have? Are you interested in selling it?
It's a blue Mk1. Battery is new but I think the guy that helped me to install it did not do a good job. So it may need some more love.
