SOLVED: How set startup volume for BeoCenter 2300?
Hello, I have a BeoCenter 2300 (or a similar model, from the 1990s). Does anybody know how the default volume (startup volume) is set? Thanks, /Jan
Solution: Models without SET button: SOUND -> PLAY -> PLAY ... until STORE? is visible in the window, then a final PLAY and the settings are stored Models with SET button: SOUND -> SET (no feedback is displayed)
Welcome to Beoworld! Thanks for posting, but your picture is actually a BeoSound 3000 which had a very different keyboard to the BC2300 and BC2500. BC2300 below: (which does have a SET button, as does BC2500)
Thanks, Guy, a BeoSound 3000! I guess the model name is somewhere underneath the tank-thick metal bracket in the back of the unit? Or is there a way to make the unit reveal its identity by the stroke of a button?
