Making AUX input work on Beocenter 9300
Hi everyone I recently acquired a Beocenter 9300, and I'm trying to connect a Bluetooth Receiver/Transmitter to the AUX input. The BT device works (I've been using it on my previous Hifi amplifier); it connects via RCA, so I've purchased an RCA - 7-pin DIN cable, and I've connected it into the TV/AUX input on the back of the Beocenter 9300. When I turn everything on, connect my phone into the BT device, and start streaming, the AUX does not activate on the Beocenter; and I can't activate it manually (pressing the AUX touch-button doesn't do anything). Since I don't have a remote control for the Beocenter, what do you suggest I do to activate it? Thanks for your help!
Only a B&O-product would talk Beolink, and make the BC to start from an input, it won't start by an incoming audio signal only. Do the other input or the standby touch-button work? Can you test it in TAPE2? The glass panel with the touch-buttons might be loose (due to aging of the double-sided tape that holds it into the frame) and the glass might have lifted on the edge of the glass panel causing the touch-buttons not to work (or needing a stronger push to first push the glass panel back down to the original position).
"Bang & Olufsen - A Life Less Ordinary" // "It's not magic, it's the Bang & Olufsen link system" // "It takes more upon itself, asks less of you. And a natural consequence of this is the simple and striking design. The true harmony of form and function spells beauty in any language"
Thanks for your reply! TAPE2 produces exactly the same result; pressing the TAPE2 or AUX buttons, with or without an input connected, does not trigger anything. Those 2 inputs can't be activated. All other pushbuttons (Radio, CD, Tape) are perfectly functional. Maybe connecting the speakers will change this behavior (they aren't connected yet, because I'm yet to receive a pair of 2-pin plugs to connect them).
