Looking for a tool to adjust Beocenter 2 distance between Keyboards and Display
Dag,
I am looking for a tool to adjust my Beocenter 2 distance between Keyboards and Display. Use the special tool delivered with the gearbox. Witch tool should I use?
After replacing parts in the Master unit, it may be nessasary to adjust the Keyboards. There are two adjustments:
1. Distance between Keyboards and Display.
2. Distance between Keyboards and bottom.
To adjust the distance between the display and the Keyboards (a), use the screw 1 (Located on the back). Use the special tool delivered with the gearbox.
