Help for BeoCenter 9000 tape. Update: it's not the belt
Update: I exchanged the belt with a one bought to Dillen a few years ago but never used. Unfortunately with no complete result : fluctuations while reading are gone but the other defects stay unchanged (see below). Any clue? Kind regards, Yann.   Hello Beoworlders, The tape unit of my Beocenter 9000 has problems. Reading works on both sides, but with fluctuations. The video below shows what happens, using a tork-meter tape (side 2 first, then side 1). link When recording, the blank" spool turns but the "recorded" one doesn't in a first step, then turns fast and the recording stops (see video below).
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Belts and tyres. You have to do them all. The place you want to buy from is called Beoparts.
Jacques
Thanks Chartz, What do you mean by tyres? Kind regards, Yann.
Please moderator erase.
Jacques
Thanks Chartz, I just had a look and these parts are for Beocord 9000 and I have a Beocenter 9000 Are you site they are adapted to my set? Kind regards, Yann
Ah ok, here BC often means Beocord. My bad, I should have watched the videos. So no.
Jacques
And did the videos give you other clues?
Update: I exchanged the belt with a one bought to Dillen a few years ago but never used. Unfortunately with no complete result : fluctuations while reading are gone but the other defects stay unchanged. Any clue? Kind regards, Yann.
Following B&Os system BC are Beocords. BCT are Beocenters. Martin (For reasons unknown to me apparently no longer Dillen).
Hello Martin, Thanks for the info, my mistake is corrected. Do you have any clue for the remaining problems? Does the reading of the tork-meter tape video shows something useful? Kind regards, Yann.
