DIY Stereo Input - Beocenter 9000/9500
Hi there! I'm the happy owner of a Beocenter 9000 and 9500. I wish to benefit from the stereo capabilities of this beast however I realized by looking into the service manual that all inputs are mono. Are you aware of any modifications that allow stereo input ?
<p style="text-align: left;">Hi,</p> When you say 'all inputs' do you mean the DIN type sockets for connection of a Phono and/or Tape2? These are stereo inputs - much the same as with almost all other Beosystems of the time. Julian
Beofan for many years with a penchant for 1990s audio systems.
i am using an echo dot as my main input device into a 9000, via a din to phono cable, this gives me stereo in and stereo out, yours should too
Hi pepps, thank you for your response. I did not know either of these were stereo as I solely based myself on the service manual diagram (see attached).   Now, do you know which pins from the DIN correspond to L/R and ground? I am making the cable myself.   Thank you !
The diagram that you posted just shows datalink - hence being headed 'computer system'.  The diagram that you need is in the same service manual as follows: (pins 3 and 5 being L and R)
