CLIP function (caller id) BC6000/Btalk1100
Dear All! My question is about the beocom 6000 mk1 in combination with beotalk 1100; they are serving now for a long time without big issues just since a few weeks the caller id (CLIP) is not shown any more; the phone company says "everything working" on some calls the function works most of the time not; the complete setup it made of Beocom 6000 mk1, BeoTalk 1100, 2 beocom 2500 and one phone on top (Porsche Design) which is not able to show CLIP does anyone has an idea? best regards Elmar
I assume that your phones are connected via a modem/router - have you tried restarting it and/or checking that the firmware is up to date? The you could try disconnecting all the phones and BeoTalk, and then trying them one-by-one to see if CLIP works individually.  Perhaps one of them is supressing the CLIP signal. You could also try a reset of the BC6000 handset and/or its base:  (make sure that you have backed up phone contacts if they are stored on the base): - Reset base: Press (dot) 7 000 8 - Reset handset: Press (dot) 7 000 9 You could also try replacing the batteries in the BC2500s.
