CD ? DVD not loading on BC2
I have a disc problem, they will not load. Some months ago I read a post giving info about a system to check the operation of the disc  player, I cannot locate it, can anyone give me the referance or the code to use please. Meantime I will consult the BC2  tech section on here! Thanks in advance
Are the wings opening ?
Yes!
I had some similar issues were the CD would not load and it turned out to be the belt for the CD tray that needed replacement. See my post here
I will check tomorrow when i visit the model boat club, I have a box of 'o'rings where i probably have the appropriate size, courtoisy of Lidl!
So my 'o' rings are 3mm diam, I assume they will not work, I as yet haven't opened the BC up That will be later in the week. Meanwhile, I have ordered some 25mm id x 1.5mm diam rings, they should also be here later in the week! Have a great festive season all who read this!!
Kose trading has a YT video where they take the BC2 apart. Very helpful.
A.K.A Capt’nGerard on the Discord
Thanks both for the leads
