Beocentre 2200 platter/flywheel not level
Good morning! My first post, hope everyone is well?
I have a beocentre 2200 which has been working lovely for the last couple of years but recently there seems to be an imbalance and I’m hoping it is an easy fix? Doesn’t look like anything has snapped etc but as you can see from the attached video, there is a slight tilt which causes the platter to scrape.
any ideas on how to fix this please?
thanks in advance, Chris
Has the center bearing come lose from the base plate?
Thanks Dillen- is that this part? Or underneath it maybe? If so, how would I fix that please?
The "skeleton" sub-platter can be lifted off.
That would ease inspection.
Thank you but that section seems to be locked in by 3 brackets and has the belt wrapped around it?
apologies, you can probably tell my knowledge is low! Thanks :)
The three locks must be rotated a little using a wide-bladed screwdriver, enough to allow
the subplatter to pass.
They will usually move in "loud chunks".
The belt will come off, and you may have to take off the black plastic surround to get at the
motor pulley to put it back (renew it and the motor mounts while in there).
Thank you! Will take a look at that :)
Chris
Hi. So this has been resolved as the circled part was not fully released.
i do now have a slight brushing sound - could that be down to needing a new belt perhaps?
Video attached
chris
The scraping sound could come from the belt rubbing on something.
If you run the deck without the platter, the belt could run on the subplatter flange.
Or it could be from the record sensing mech.
Have you tried with a record on the platter?
Hi
seems like a possible belt issue? Videos attached.
thanks
chris
