I wouldn’t risk damaging the fine old BeoCenter so I need some expert advice. Thanks for reading and double thanks for commenting. Have a nice evening.
Best regards
Peter
Login to view image
Login to view image
Thanks Beoboddy for your quick reply! Where does + and - go then? The + sign says it self, but what about the - (minus)?
Best regards PeterLocation: Warwickshire, UK
