Beocenter 9000 with active/passive speakers
Recent came across a beocenter 9000 and also have beolab 6000 and beovox rl60.2 is it possible to connect both speakers to beocenter and use together? beovox to speaker output and beolab to line out pre amp.
There's no volume control on the pre-amp output, so you'll need to find another solution. (EDIT:  Actually there is volume control of pre-amp - I was thinking of line- out!  Hence this should be useable for Beolabs)) Have a read of the second part of Steve's response here: https://forum.beoworld.org/forums/topic/beomaster-3000-naar-powerlink/#post-5835 You could use the speaker 2 sockets (via attenuator) for the Beolabs.  Be aware that the BeoCenter's 'Mute' control would only work for the speaker 1 pair in such a setup, and does not mute the 'pre-amp' output. I am sure that Steve will be along in a minute to confirm the correct cables!
