Beocenter 9000 lights up but nothing more. Help please
Hello Beoworld people!
I bought this Beocenter 9000 a while ago that won't work. I don't know whats wrong? When I plug it in I hear relays clicking and it lights up but thats it. Nothing happens when I press any of the touch buttons.
If anyone have a clue what could be wrong I would very much appreciate it.
Regards,
Rickard
Login to view image
My approach would be to first check out the power supply as there are multiple ones in this unit along with 4 fuses. You can get the service manual at https://beomanuals.com/manuals/Beocenter/Beocenter%209000/Bang-Olufsen-Beocenter_9000-Service-Manual.pdf
If you have an appropriate remote (Beolink 1000, Beo4, iirc), try that. There can be failure in the touch-sensitive glass, while the balance of the unit is ok.
