beocenter 7700 cassette runs at half speed
Hi. I have a beocenter 7700 that I'd changed all the cassette belts on - then let it sit for 9 months. Now the tape player plays at half speed.  I've also noticed that the motor is always running - even if the radio is playing. Also (sorry there's a few) the belt on the smaller wheel underneath the tape deck seems to be rubbing on the large aluminium wheel. That doesn't seem right. Any ideas? Thanks
Check the DC voltage to the motor with a scope. Look for correct voltage and amount of ripple. Martin
Thanks will check it out. I have a feeling it's something mechanical - as the position of the wheel with the smaller belt doesn't seem right. I'll check both. Appreciate it
it seems to be that the pads that hold each spindle (that fit into the casette) aren't being released so are providing pressure hence the slow speed. Trying to track down what releases those pads - any idea if both spindles get released upon play? Thank
Did you lubricate using something that evaporates or dries? Martin
