Beocenter 7700 back panel stuck
Hi everyone. The back panel of my Beocenter 7700 is not rotating up. I need to replace the belts on the cassette deck and cannot access the screws that allow the unit to be opened up. Do not want to force it. It seems to be locked. Any advice appreciated.
By back panel are you referring to the black grill that covers the connections? If you are it is only held by gravity. There is a stop piece attached to the underside in the middle of the grill piece that might have gotten stuck down.
