BeoCenter 7000 turntable cover hinge Or spring holder
Hi All, I had the same issue on my Beocenter 7007 turntable hinge that was continuously falling like described in this archived thread: https://archivedforum2.beoworld.org/forums/t/37193.aspx It’s not a question that I have but more an answer to those looking for a solution, hence I’m launching this topic for the record. I made a 3D model that you can print to address this issue: https://www.thingiverse.com/thing:6794011 It’s not too difficult to assemble everything back together but you need to be cautious and not focus too much on the spring. Hope this helps!
Available in polycarbonate, injection molded : https://www.dksoundparts.com/product/beocenter-5000-7000-7002-spring-holder-for-turntable-dust-cover/ Martin
Thanks Martin! Knowing this would have saved me couple of hours especially since I placed an order recently to them for the capacitor kit of my S45-2, so if I knew it before I would have ordered it too 😅. Thanks!
