Beocenter 6 with Beosystem 3 and Beocenter 2: How?
Hey,
maybe somebody can help to get this nice vintage setup to work. :-)
I want to install the 3 B&O items in our sleeping room:
- Beocenter 6-26
- Beocenter 2 DVD
- Beosystem 3
But:
- How do I get the sound from Beosystem 3 sources AND the Beocenter 2 out of the Beocenter 3 speakers?
- How to prevent double commands for Beosystem 3 and Beocenter 6?
Option settings, yes, but how. I want e.g. "V.Mem" to start the Beocenter 6, Beosystem 3 but don't want both to react to volume commands. I setup the Beocenter 6 as "non B&O monitor" on the Beosystem as it only knows Beovision4 and 12.
Of course it should be user friendly as my wife and kids should be able to use it easily.
When I only connect the Beocenter 2 with the Beocenter 6 via Masterlink I can listen to Radio, CD and Aux from the Beocenter 2.
But as soon as the Beosystem 3 is here, the trouble begins. ;-)
Hello TWG, what is the reason you want to use the BeoSystem 3? For its HDMI inputs? Regards, Johan
Hello Johan,
yes, the Beosystem 3 manages the HDMI inputs (Streamer, Blu-Ray...).
Hello Johan,
Here are my ideas (with no guarantee of success)
I would create a small ML network including the 3 items use a ML distributor if you have one).
Beocenter 6 has the speakers, so I would set it on Option 2.
Beocenter 2 set to Option 0 so that it is controlled by the BC6. If needed, a scart cable may distribute the video for DVD.
BS3 could be seen as a link product placed in the main room. So option 4.
All video inputs of BC6 disabled except the one connected to BS3 and SCART if you use it.
In BS3, do not use these input names for it's video sources.
Then the problem is to control the BS3 sources.
BS3 can be "called" with command Link + source name, which can be added in the Beo4 list (eg L-DTV2, L-V.AUX...).
As an alternative and if you have a spare Beo4, you could program it in order that it only sends Link command (access to "Config?" as you do for option programming, press 2 0 0 2  then Exit - Same way to turn the Beo4 to normal mode).
I hope it helps. If it doesn't, look at the Beolink Handbook link available on the right of this page.
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Another idea that will work best for video sources is to set the BC6 in option 4. That way you can activate the BC6 with a Link + the video Source button assigned to the video input for the BS3.  The volume should be set at a fixed level so the volume is controlled from the BS3
The BS3 in option 2 and the BC2 in option 0 should the be controlable by normal commands with all sources available.
However if you will just listen to music with this setup you will still have to activate the BC6 with the Link + Video command first. This could be avoided by attaching a set of speakers to another set of PL connctors on the BS3 and assign that speakergroup to music.
Not optimal but hope it can help getting some ideas
Thanks for your input. So it seems a little more complicated than originally thought ;-)
