Beocenter 2200 Lid Replacement
Hello, would anyone be able to tell me how to remove the plastic lid on a Beocenter 2200? Mine has a crack in it and I want to replace it, but I’m struggling to see how to get the plastic lid unscrewed from the hinge?
Many thanks!
You need to take off the whole rear piece with the hinges etc.
Then you remove the two small plastic covers under the lid to reveal the screws.
Ask at Danish Sound Parts if you need a replacement cover, they may very well have a good used one in stock.
