Usually on other turntables you just pull the lid off , but this one seems more complicated...
Do I need to take the whole thing apart? Screwed off all the "C" screws, but the turntable still won't come off, do I need to unscrew all the "A" screws as well?
Also is the size of the belt important, someone told me I could just glue the belt together at the breaking point...
