Beocenter 2200
Hi. I recently inherited my fathers 2200 and it plays beautifully. But the turntable makes a ticking noise which is very evident when playing a quiet record. B&O tech in Barcelona tell me they cannot fix due to parts not being available. Any guidance?  Thank you.
What parts are not available?
Check if the motor bushing touches the metal bracket.
If it does - replace the motor mounts.
https://www.beoparts-shop.com/product/motor-suspension-rubber-bushing-grommet-f-several-beogram-beocenter-models-2/
If the motor itself is noisy, it must be taken apart and repaired (most can be)
- or replaced, and a good condition used original motor would be the way forward in that case.
Thank you. I will investigate.
