Beocenter 2 LED flashing red
Dear all,
I have a Beocenter 2 that is connected to Beolab 3 speakers and a Beolink System.
When I connect the Beocenter 2 master and socket unit, the master unit LED flashes red but the screen does not turn on.
Neither pressing the remote nor touching the control panel of the device has any effect.
When I connect it to the Beolink system, all speaker and IR receiver LEDs turn on (red) but nothing changes on the master unit.
I could only find that the flashing LED might indicate an error, but not which one.
Any advice for solutions or troubleshooting?
Many thanks in advance!
Best,
Dimo
The blinking red LED usually means that the PIN code has to be entered.
Regards,
Y.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Thanks YannChris, makes sense, but usually it should show something on the display while blinking, shouldn’t it?
Best,
Dimo
You are right, it should.
