For one thing belts. Beoparts shop has the belt for the Door mechanism, so no problems there.
But the Belt for the CD tray mechanism also seems to be a little loose (The tray can not fix the CD in place) , but Beoparts shop does not have a belt that will fit.
Does anyone have an alternative for this?
The Belt is round, 1.5mm thick, and aproximately 30mm outside diameter. The correct outside diameter may of course be a smaller number since the belt is loose.
Thanks in advance
