BeoCenter 2 - wall mount assebly
Hi, I just bought a wall bracket to my BeoCenter 2 and I can't figure out how it works. There is a wall plate, that can be mounted wit h3x screws to the wall, which has a single a pin that connects to the small "table" which the unit sits on. However, when mounting wall plate with the pin to the "table" there is nothing that keep it in place (it can spin around the pins axis). Any ideas? Thanks!
Your wall plate should have an offset square pin in the centre. Mount your plate to the wall using 3 strong screws. Mount the table stand to the backplate by rotating it clockwise on. It should sit comfortably in line with the backplate. Mount your BC2 to the table stand using 2 grub screws. Connect your master cable and you're good to go. ?
