The BC 9500 came with two different cassette mechanisms. The early production units came with a 2 motor mechanism that required connection to a small circuit board mounted on the bottom of the chassis before going to the controller board (this is the big circuit board mounted right behind the sliding doors).
Later production units used a single motor mechanism and it connected directly to the controller board.
Does anyone know if the two cassette mechanisms are interchangeable with the tape controller board? In other words, can I swap one mechanism for the other using the same controller board?
Thanks,
Derek
