sudden issues with N.RADIO?
Hi all!
 My PC2 set-up has been working perfectly for two years, but suddenly I cannot listen to almost any N.RADIO stations at all. Beoport refuses to connect to all swedish ones and works basically with randomly selected foreign ones. I find this really strange for two reasons
a) I have not touched my B&O system, nor my PC - so did it suddently start failing
b) I'm still connecting to a few stations so it's not the network
Any advice would be welcome
thanks //anders
Hello Anders.  It sounds as if you have reverted back to the sampling of NRADIO that comes with a basic BeoPlayer installation, rather than BeoPort.  I would recommend starting over with BeoPort software.  Also, it tends to work better when you completely uninstall the old version.  Hope this helps.
Ray
