N.RADIO on Beomedia1 not working-Please help
My Beomedia1 hooked up to my BV7-32 was working as should for some time now. It seems that something happened and now i can access all menu normally, but when i press N.RADIO it says ..<<Not registered!>. My PC on the other end of the network has the Beoport programm running normally. Is there an issue with the server? I tried all kind of resets and even reinstalled Beoport on the PC, with no luck. Any help would be appreciated, thanks!
No problems with the server - my BM1 is playing netradio witout any problems.
when you reinstall Beoport, are you prompted to registrer again with your username and password?
I did a recovery a few times, and every time I had to reinstall beoplayer in order to registrer my user again during the installation process, otherwise it said " not registered"...
Thank you Martin for the reply. I had to restore Beomedia1, then reinstall (after uninstalling) Beoport and everything goes fine. When i try to register Beomedia, it says it needs a password to find it. I think it is blank by default but it just does not find Beomedia, although on same Network. If i skip this step i can register Beoport with no problem and have N.RADIO on my PC. It is a matter of my PC <<not seeing>> Beomedia. Do you remember what is the default Beomedia password?
After you do the recovery, you have to set the password yourself  in the BM1 menu (red - 9 - 0 - 0 - Go - Network settings (as far as I remember)
This is the password you have to type when you connect to the BM from your computer
Ok Martin, you are right. Done that….So now they see each other finally!
BUT…..still N.RADIO on BM1 shows not registerd. (Although i have completed the procedure on my PC) . Any more ideas?? Thank you for your help so far!
Finally, after A LOT of experiments and resets the system is up and running again as it should. If you ask me i am not sure what caused this but it is fixed now. A big thanks to Martin for his help and to my friend Spiros who rushed to call me after my initial post in order to help me out! 🙂
Always next to my friends.....
Glad to hear that it works again!
BR
Hi Dimitris,
great to hear everything works for you :-)
when you did a recovery on the Beomedia 1, did you also get the software update for BM 1?
