BS9000 and PC in different rooms?
I am planning to get a Beoport to enjoy N.MUSIC. My setup is that BS9000 is in the livingroom and the computer in a MCL link room. Is this kind of product placement supported by Beoport or do all the main components (audio master, pc and Beoport) need to be in the same room?
Definately no reason to be in the same room, not sure though about the MCL. I have a setup with Beoport in the study and the BS9000 in the living room listening to N.MUSIC in the whole flat. This is all wired with ML.
Cheers,
Frank
Thanks,
This clarifies my case. MCL might cause an issue because I need to find a way to attach the Beoport to the MCL cabling or link unit. The only way I could think is the MCL2-AV and one of the connections there. I do not know if they are two way and support Beoport though.
Don't think you can connect via the MCL network you have. Your Beoport will have to be connected to the BS9000 with a Masterlink connection.
Craig🙂
