Dear all,
I had a very strange expreience yesterday.
I was an idea to add a Belkin Bluetooth receiver (http://www.belkin.com/IWCatProductPage.process?Product_Id=508754) to my Beocenter 2500+Beolab4500 system via the AUX connector, but it had the most strange behaviour I've ever seen. The sound turns on, but it sounds like DIGITALLY JAMMED, just like if You try to listen to a very badly scratched CD, or an extraim wrong digital connection, some data is missing, some frequency are missing, and it's sounds totally fake! Unfortunately, I was not able to record it, but imagine the sound like this (noisy!) http://www.youtube.com/watch?v=dzvvk9BBC30 with some bad quality music in the background.
Of course, my first thought was, that the digital link or the receiver is wrong, so I tried to use the receiver and the dongle in just inches away, but there was no difference. After this, I started to test the items, and:
- The receiver works absolutely fine with my notebook, so there is no problem neither with the receiver, nor the transmission,
- I replaced the music source with a different bluetooth source (mobile phone -> PC), but there was no change, the behaviour remained the same,
- I changed the source and the destination computer - the system worked just perfect.
There was only one strange thing: The 5 pin connection to the Beocenter seemed a little bit grounding problem (there was the usual deep growling sound), but as I was used a brand new 5 pic connector, it can't be the problem, so I thought, maybe the connector is wrong inside the Beocenter 2500. So to check it, I was tried the bluetooth system in my other Beosystem 2300, and...
... IT WAS ACTED THE SAME WAY!
So, the only part I was not replaced was the 3.5 jack-5 pin connector, BUT the problem seems totally different, as the sound is not bad - with for example a huge noise in the bacground - but JAMMED, just like a real bad digital sound!! How can it be, as an audio connection can not act this way?
OR, is it possible, that BEOCENTERS use DIFFERENT connectors, as all the other 5 pin DIN connectors?!
Have You ever had an experience like this? Do You have any idea on what else can I try? 🙂
Thank You for reading, and in advance!
