2 questions about the Beoport: version 4.83
1. I have read on this forem you can view Mpeg files via N.Music with the right codexs. Where can I find them? Will AVI files also work?
2. For Photo’s the My Pictures directory is used. Can you add more directories of network drives as file locations?
Kind regards, Edwin
Hello!
1.- AVI or MPEG files works great with Beoport if you use the right codecs (if you can watch the videos with WindowsMediaPlayer, then beoplayer also can), but you must use the PHOTO command-section, not N.Music.
2.- Correct "My pictures" is the default folder, but you can always "drag and drop" any file from any folder, directly over beoplayer and you will get it.
we can watch videos using PHOTO not only with the beoport 4.83 version, but from the very first 4.01 version of beoplayer which had the PHOTO capabilities, some years ago.
