Beoport and Beoplayer
Hi
Could anybody tell me if you need to use Beoplayer as the media player on a PC  between Beoport and N.Music on a Beosound3200 ? I find beoplayer awkward and clunky to use. Any ideas would be appreciated.
Tony
There has been a similar debate elsewhere this past week.
One poster was arguing to just use the hard drive in the Beosound 3200.
Personally I have never favoured trying to key in the names of CDs through the Beosound.
I do not find BeoPlayer too bad.  I actually liked its "style".  Others have found it too minimalistic.  But I agree try to control BeoPlayer through the Beo4 does tax one's memory.
But BeoPlayer is what you are "stuck" with if you have a Windows machine.
Unless you want to contemplate switching to a Apple Mac for your media server; or an audio distribution system like AirTunes (soon to be AIrPlay .... on Windows?)
If you have an Airport express you can broadcast from iTunes to the Airport and have it plugged into the Beosound 3200 as a AUX input.
Your track selection etc control then has to be an iPhone running Apple Remote app.
As I suspected, B&O are not making it easy for me to purchase there products.
That has put me off purchasing the system
Tony
really ? !!!
You have decided not to buy a BeoSound 3200 ? or not buy the BeoPort ?
I am very happy with my "system" which I am listening to right now ...
a MacMini delivering beautiful mellow jazz to two beloab3s and a beolab 11.
The beosound would be fine, but I am looking to integrate my vast collection of music on my hard drives to it. It would be good to use the same remote for media player as BS3200. I do not want to use Beoplayer.
Anyway I will keep digging around for further info
Tony
I assume I could still play windows media player through the beoport to teh BS3200?
Tony
Tony
You can interface the PC to the AUX-in without a BeoPort and use whatever Windows player you want.
What you loose is the ability to control of the BeoPlayer functions via the Beo4.
If you find it acceptable to use the PC's keyboard (or its AV remote, like one of my wife's laptops had) then you may have what you wanted.
However if your PC is far away from the BeoSound 3200 you might want to look at something like the Airport Express.
But other people here have used many other solutions ... do a search for SONOS on Beoworld to see how some others have achieved digital integration.
That sounds good. I have just looked at the AirportExpress on the Apple website, it looks like I could stream music from itunes on a windows based PC. Do you think this is correct ?
yes, I used to do that from Windows before I acquired my Macs
Have been using Free edition of MediaMonkey to stream music from my PC using the AUX input on a BEO 9000, works fine.
Have recently tried Beoplayer on the same PC using Windows 7, which encounters a problem when searching the computer with NMUSIC.
The displayed message is "Beonetmusic stopped working", it then shuts down.  Was wondereing if any body else has had a similar problem.  Have spoken to local B&O dealer who could not offer any advice.
Thanks.
Delboyone
