BeoPort 4.65 & Sound Problem
Having moved my PC I've now reconnected my BeoPort box, clean installed 4.65 s/w and although when I select N.Music / N.Radio from a link room they start on my PC I get no sound in the link room.
 Any ideas why?
Gavin
I suppose it must be an option setting problem. What option is the Beoport set to? Is it different to what it was. Try unplugging and plugging back in just in case it is a ML crash.
Thanks Peter, it's set to option 6, which I think is the right option and how it has always been set. I'll try changing to another option and back to 6, unless that's the wrong option? I'll also try unplugging and see if that works.
Gavin
Definitely try switching the whole system off and then on again. ML gets a bit precious about disconnecting and reconnecting in muy experience! And my Beoport box has its moments too!
Had a similar problem after upgrading to the latest version of BeoPort.
After some deinstalling and reinstalling I found out, that the latest version of Windows Media Player is necessary. Now everything works how it should.
