Beomedia ir wiring to eye
Dear friends
I have my BM1 connected to my BV5 (first generation) using scart but now need to wire the ir cable into a eye - can anyone tell me where the Yellow, Brown & Green wires connect into the corresponding eye connections (my one has 5 slots) - currently have it connected as follows:
  • Yellow = 1
  • Green = 3
  • Brown = 5
this I worked out from the wiring diagram off Beotech (http://www.beoworld.org/beotech/wiring4.htm)
does anyone else have a similar set up that they could help me with the wiring
Thanks, Hughie
Ok - I seem to have solved the problem by moving the yellow wire into No4 and so the wires into the magic eye look as follows:
  •  Green = 3
  • Yellow = 4
  • Brown = 5
all seems to be working now - just need to change the scart connections from v.aux to run off the PC command on the Beo4
